BigFix Remote Control support for macOS15 (Sequoia)
Today the fixlet for RemoteControl Target (10.1.0.0128) as well as RemoteController Controller (10.1.0.0128) with IDs (92,100, 101, 94) are all relevance contained to (it >= "10.11" AND it <= "14") of system version
However, the documentation states that macOS sequoia is supported:
MacOS Sequoia went GA on Sept 16; when should we expect the BFRC components to allow support of this macOS version or does anyone else see the same issue?
I’m sorry but there an error in the documentation, we opened an internal defect to remove Sequoia from the current supported OS.
The support of Sequoia is planned for next year (likely in the first quarter) because Apple did major changes to the screen capture technology in Sequoia version, so we need to perform a re-engineering of the solution.
I can confirm that it does not look like 10.1.0.0128 works with Sequoia. Performing the reset below makes it look like it’s going to work as the screen resizes on the Controller end, but ultimately it still does not allow you to view anything on the Target screen.
For anyone that falls into this thread; take a look at the companion post:
