I have got the content of /test.txt file as below:
Content1:
Type = abc
Range = 123
Account = abc123
Content2:
Range = 456
Account = egf456
Content3:
Type = xyz
Status = status123
Requirement:
Need to fetch the paragraphs of the above file containing certain string.
Eg:
Fetch the paragraphs containing “Type” keyword.
Expected Output:
Content1:
Type = abc
Range = 123
Account = abc123
Content3:
Type = xyz
Status = status123
I have tried the below relevance:
Q: (substrings separated by "%0d%0a" whose (it contains "Type") of concatenation of lines of file "/test.txt")
A: Content1: Type = abc Range = 123 Account = abc123Content2: Range = 456 Account = egf456Content3: Type = xyz Status = status123
This prints the entire file and not the expected output.
BigFix inspectors support the reading of “ini” file. If you have a chance to generate a standard ini file then it would be very simple as shown in the following example:
[Content1]
Type=abc
Range=123
Account=abc123
[Content3]
Type=xyz
Status=status123
Q:key “Type” of section “Content1” of file “sample.ini” of folder "c:\TEM"
A: abc
T: 0.061 ms
If not then you have to play with the line of file inspector, use a combination of “substring” , “line starting” and “next line” . I can’t provide a precise example that fit your case. May be someone on this forum can be more precise.
You were close. I think you need to inject a placeholder for your empty lines, concatenate with “|” then break apart on those injections, filter for your “Type” and then breakdown on the “|”
q: concatenation "|" of (if it = "" then "<LINEBREAK>" else it) of lines of file "c:\test\test.txt"
A: Content1:| Type = abc| Range = 123| Account = abc123|<LINEBREAK>|Content2:| Range = 456| Account %09 = egf456|<LINEBREAK>|Content3:| Type%09 = xyz| Status = status123
T: 2.454 ms
I: singular string
q: substrings separated by "<LINEBREAK>" of concatenation "|" of (if it = "" then "<LINEBREAK>" else it) of lines of file "c:\test\test.txt"
A: |Content2:| Range = 456| Account %09 = egf456|
A: |Content3:| Type%09 = xyz| Status = status123
T: 1.881 ms
I: plural substring
q: substrings separated by "<LINEBREAK>" whose (it contains "Type") of concatenation "|" of (if it = "" then "<LINEBREAK>" else it) of lines of file "c:\test\test.txt"
T: 1.262 ms
I: plural substring
And Finally
q: substrings separated by "|" of substrings separated by "<LINEBREAK>" whose (it contains "Type") of concatenation "|" of (if it = "" then "<LINEBREAK>" else it) of lines of file "c:\test\test.txt"
A: Content1:
A: Type = abc
A: Range = 123
A: Account = abc123
A:
A:
A: Content3:
A: Type%09 = xyz
A: Status = status123
T: 0.660 ms
I: plural substring
q: (it as trimmed string) of following texts of lasts "=" of substrings separated by "|" whose (it contains "Type" and it contains "=") of substrings separated by "<LINEBREAK>" whose (it contains "Type") of concatenation "|" of (if it = "" then "<LINEBREAK>" else it) of lines of file "c:\test\test.txt"
A: abc
A: xyz
