We have bigfix application installed on windows 2012 and unfortunately it has to be removed. now on the same device i want to install application back again.I have masthead and cert files which are backed up but not sure in license file and SQL is also as it is.
is it possible to use recover bigfix using masthead file on the same device?
I believe you will need your site signing private key (and it’s password) if you are going to use the same masthead file and keep your existing deployment.
Otherwise you can contact Bigfix Support to generate a new key pair and new masthead file. The new masthead would need to be loaded on each endpoint to attach them to your new deployment.
yes, on that note i tried to get the backup of all files of the server which are used, below are the list
1.license.crt
2.license.pvk
3.LicenseAuthorization.BESLicenseAuthorization
4.masthead.afxm
so i can reuse the license file on same device for bigfix application installation?
