I am passing this query and not able to get the operating system as an output.
https://host:52311/api/clientquery
body
<BESAPI xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BESAPI.xsd"> <ClientQuery Resource="https://host:52311/api/clientquery/2391"> <ApplicabilityRelevance>true</ApplicabilityRelevance> <QueryText>name of operating system</QueryText> <Target> <ComputerID>{computerid}</ComputerID> </Target> </ClientQuery> </BESAPI>
could you please help.
You can’t just use {computerid} as the Target value. You need an actual, computer id value there (the number).
{computerid}
You could obtain the computer id value to use in one API call, and then use that to build the xml value for a second call to clientquery.
you can’t just pass the computer name. Name is easy instead of computerID if you 1000’s of computers.
