Hello
I want to see installed software information in ILMT and I will calculate PVU license usage in IBM product.
To do this, I should follow some steps in BigFix Console:
First, I need to activate analysis. For example, installed UNIX packages, installed Windows Apps and Software Scan Status (It is done)
Second,Install software scanner. I applied the target computers on Bigfix Console.
Third, Initiate software scan. This steps takes more than 10 hours, and it shows 25.53% completed, 74.47% is not reported. It takes lots of time and I’m not sure it is normal.
Fourth, Upload Sotware Scan Results. I clicked on Take Action and I selected target computers and at this time it shows, 0.0% is completed, 100.0% is not reported.
What was the main cause of the issue? Which logs should I check? How can I solve this issue?
Kerem
