BigFix IVR v4 and manual import
We’re looking into BigFix Insights for Vulnerability Remediation, and noticed that support is mainly focused on Tenable with v4. We did some testing in the past with version 2.0 and there you had the option to manually import data from another solution (ex. CrowdStrike).
We did ask at the time already if their would be future integration with Crowdstrike considersed.
Question?
With version 4 is the option to do manual import not available anymore, I cannot see it in the screenshots of the documentation, also when I look at the screenshots for the installation only option again is Tenable.
Any plans for CrowdStrike integration?
Import is possible when using IVR v3, which uses the Insights database for correlation. The process is documented (oddly enough) in the WebUI User’s Guide: IVR List.
