BigFix IVR module installation
We are not using any Tenable, Qualys, or Rapid7 scanner tools. How do we install the BigFix IVR module?
Are you using some other network scanner tool then, and what are your expectations for IVR ?
Can we use a CSV file in an IVR module without any Tenable, Qualys, or Rapid7 applications? If yes, can you please guide me?
Sure, we have instructions on importing a CSV for IVR at IVR List
