We have installed BFI for iSeries, and is using a lot of resources.
Hello,
Can you be more descriptive of your problem? If you provide more details, I will be able to ask dev team to take a look.
Here is the response I got from iSeries Bigfix Inventory support regarding heavy CPU usage during software inventory.
Hello,
You can optimize the processor utilization during the scan by setting up the CPU threshold.
- Edit the sw_config.xml file that you downloaded with the scanner.
- Add two new cpuThreshold attributes, one for FSScanner and another for Signatures, like in the
following example: ( the parenthesis would be replace by <>)
(<IBM)
(CIT)
(XSE version=“1.0”)
(Plugins)
(Plugin name=“FSScanner”)
(Attribute name=“cpuThreshold” value=“20:2:150:850”/)
(Attribute name=“interruptOnTimeout” value=“true”/)
(/Plugin)
(/Plugins)
(Signatures)
(/Signatures)
(/XSE)
(/CIT)
(/IBM)3. Specify one of the following values:
Desired
utilization Value
5% 10:2:50:950
10% 20:2:100:900
15% 20:2:150:850
20% 30:2:200:800
25% 30:2:250:750
50% 50:2:300:500
