I’m trying to install BigFix on a Virtual Server with the Operating System of Photon 2.0.
Since there is not install for photon I’m trying the Redhat version using the below command;
rpm -ivh BESAgent-10.0.3.66-rhe6.x86_64.rpm
resulting with the below
warning: BESAgent-10.0.3.66-rhe6.x86_64.rpm: Header V3 RSA/SHA256 Signature, key ID 16055553: NOKEY
I have grabbed the masthead.afxm from http://server:52311/masthead/masthead.afxm and renamed this to actionsite.afxm placing it in /etc/opt/BESClient as per the instruction but I still get the NOKEY message and the software is installed as if i try run this again i see package BESAgent-10.0.3.66-rhe6.x86_64 is already installed.
Next issue is when i try to run /etc/init.d/besclient start I get the below;
Starting BigFix: BESClient: /opt/BESClient/bin/BESClient: error while loading shared libraries: libacl.so.1: cannot open shared object file: No such file or directory
[FAILED]
Any assistance is welcome,
Thanks,
Hayden
