Are there any BigFix Inspectors to check crontab entry?
There is no dedicated inspector for crontab, but you can export to a file via fixlet.
wait sudo su - root -c "crontab -l > /some/path/crontab.txt"
Then have an analysis utilizing file and string inspectors to parse the crontab export file.
