Currently we have Bigfix application on Linux server with DB2 database due to some issue we want to move Bigfix server db2 database to other mount point. . Please provide the steps so that we can perform database movement from current mount point to another mount point.
From a BigFix perspective, the mount point should be irrelevant as it just knows what server to talk to on what port. If you are not changing the server, then this is all DB2 configuration and I would talk to your DB2 admins.
High level
Stop BigFix services
Move database
Start BigFix services
Depending on how long this will take, you might also want to consider some of the configurations for the agent report times, just like you would do in an upgrade.
