Hi Everyone, We are unable to login console after upgrade to 11.0.7.
We can login using local credential and verified that test connection successfully in LADAP.
Please open a ticket. I have the same thing but we have SAML in the middle. Our SAML uses the username Firstname.Lastname while LDAP is using firstname.lastname and support is saying it is case sensitive, but worked under 11.0.6? It may be something else so the more tickets the more attention it will get.
I just updated my DEV with the same issue. I have already opened a ticket with HCL. Stay tuned.
Did you got any solution from HCL.
I have not. They were blaming uppercase vs lowercase usernames eventhought it worked in 11.0.6….
Please update us if you get any solution.
HCL has officially acknowledged a product bug within the BigFix v11.0.7 release that causes this specific Active Directory/LDAP console login failure.
As confirmed, there are no configuration or infrastructure issues on the customer end, given that our backend LDAP tests, local account access, and server resources are fully functional.
HCL engineering team is actively working on a hotfix or an updated software version to address this defect.
HCL had shared BESROOT.EXE , after replacing the current exe issue got fixed.
Please share the KB article for it once it is created.
Hello,
we identified a bug in BigFix Server 11.0.7, following the release of a new feature related to LDAP: the DA reference is KB0134454 and is currently waiting to be published.
In the meanwhile, we have been working at the BigFix Server hotfix, that will be shared with every customer hitting the issue.
We have also sent a testfix to customers who already reported the issue.
Please note a hotfix is now generally available to address this problem:
