Product:
BigFix Compliance
Title:
Updated DISA STIG Checklist for RHEL 8 with bugfixes
Security Benchmark:
DISA Red Hat Enterprise Linux 8, V2R7
Published Sites:
DISA STIG Checklist for RHEL 8, site version 29
(The site version is provided for air-gap customers.)
Updated Fixlets:
A separate RHEL 8 filesystem must be used for the /tmp directory
RHEL 8 must disable mounting of cramfs
RHEL 8 must use cryptographic mechanisms to protect the integrity of audit tools
RHEL 8 remote X connections for interactive users must be disabled unless to fulfill documented and validated mission requirements
RHEL 8 must not allow users to override SSH environment variables
All RHEL 8 local initialization files must have mode 0740 or less permissive
RHEL 8 must be a vendor-supported release
RHEL 8 must disable the transparent inter-process communication (TIPC) protocol
RHEL 8 passwords must have a 24 hours/1 day minimum password lifetime restriction in /etc/shadow
RHEL 8 must use a separate file system for /var/tmp
RHEL 8 must disable IEEE 1394 (FireWire) Support
RHEL 8 must disable the stream control transmission protocol (SCTP).
RHEL 8 Bluetooth must be disabled
All RHEL 8 remote access methods must be monitored
RHEL 8 operating systems booted with a BIOS must require a unique superusers name upon booting into single-user and maintenance modes
Additional details:
Both analysis and remediation checks are included.
Some of the checks allow you to use the parameterized setting to enable customization for compliance evaluation. Note that parameterization and remediation actions require the creation of a custom site.
Improved a few checks by adding the pending restart feature to them. The pending restart feature works in the following ways:
The action results will show “Pending Restart” instead of “Fixed” for those checks which require OS reboot.
The check will show relevant for those endpoints until they are rebooted.
Post reboot of the endpoint the action results will show as “Fixed” and the check will be compliant.
Action to take:
To subscribe to the above site, you can use the License Overview Dashboard to enable and gather the site. Note that you must be entitled to the BigFix Compliance product and you must be using BigFix version 10.0.0 and later.
If you use custom sites, update your custom sites accordingly to use the latest content. You can synchronize your content by using the Synchronize Custom Checks wizard. For more information, see Using the Synchronize Custom Checks wizard
More information:
To know more about the BigFix Compliance SCM checklists, please see the following resources:
BigFix Forum:
Compliance (Release Announcements)
This category is used by HCL to announce new releases for BigFix Compliance.
BigFix Compliance SCM Checklists:
SCM Checklists
This category is the central reference for all SCM Checklists supported by BigFix Compliance. It covers the complete list of active checklists across all supported frameworks and platforms, including CIS, DISA STIG, PCI DSS, NIST, and more, along with site name, version details, and supported OS versions.
We hope you find this latest release of SCM content useful and effective. Thank you!
– The BigFix Compliance team
