Product:
BigFix Compliance
Title:
Updated DISA STIG Checklist for RHEL 8
Security Benchmark:
Red Hat Enterprise Linux 8 Security Technical Implementation Guide, V2R9
Published Sites:
DISA STIG Checklist for RHEL 8, site version 30
(The site version is provided for air-gap customers.)
Details:
Total New Fixlets: 6
Total Updated Fixlets: 15
Total Deleted Fixlets: 1
Total Fixlets in Site: 365
New Fixlets:
RHEL 8 must log IPv4 packets with impossible addresses.
RHEL 8 must log IPv4 packets with impossible addresses by default.
RHEL 8 must use a reverse-path filter for IPv4 network traffic, when possible, by default.
The RHEL 8 SSH daemon must be configured to use systemwide crypto policies.
RHEL 8 must implement DoW-approved encryption in the OpenSSL package.
OS must generate an audit record for all successful and unsuccessful uses of the useradd command.
Updated Fixlets:
RHEL 8 must prevent the installation of software, patches, service packs, device drivers, or operating system components of local packages without verification they have been digitally signed using a certificate that is issued by a Certificate Authority (CA) that is recognized and approved by the organization.
RHEL 8 must implement address space layout randomization (ASLR) to protect its memory from unauthorized code execution.
The RHEL 8 SSH private host key files must have mode 0600 or less permissive.
RHEL 8 must automatically lock graphical user sessions after 10 minutes of inactivity.
RHEL 8 must allow only the information system security manager (ISSM) (or individuals or roles appointed by the ISSM) to select which auditable events are to be audited.
The RHEL 8 fapolicy module must be configured to employ a deny-all, permit-by-exception policy to allow the execution of authorized software programs.
The systemd Ctrl-Alt-Delete burst key sequence in RHEL 8 must be disabled.
RHEL 8 must not allow IPv4 ICMP redirect messages.
RHEL 8 must use reverse path filtering on all IPv4 interfaces.
RHEL 8 must enable hardening for the Berkeley Packet Filter Just-in-time compiler.
RHEL 8 operating systems booted with United Extensible Firmware Interface (UEFI) must require authentication upon booting into single-user mode and maintenance. RHEL 8 operating systems booted with United Extensible Firmware Interface (UEFI) must require a unique superusers name upon booting into single-user mode and maintenance.
RHEL 8 must ensure the password complexity module is enabled in the system-auth file.
RHEL 8 user account passwords must have a 180-day maximum password lifetime restriction. RHEL 8 user account passwords must be configured so that existing passwords are restricted to a 180-day maximum lifetime.
RHEL 8 must cover or disable the built-in or attached camera when not in use.
Deleted Fixlets :
RHEL 8 must enable the hardware random number generator entropy gatherer service.
Additional details:
Both analysis and remediation checks are included.
Some of the checks allow you to use the parameterized setting to enable customization for compliance evaluation. Note that parameterization and remediation actions require the creation of a custom site.
Improved a few checks by adding the pending restart feature to them. The pending restart feature works in the following ways:
The action results will show “Pending Restart” instead of “Fixed” for those checks which require OS reboot.
The check will show relevant for those endpoints until they are rebooted.
Post reboot of the endpoint the action results will show as “Fixed” and the check will be compliant.
Action to take:
To subscribe to the above site, you can use the License Overview Dashboard to enable and gather the site. Note that you must be entitled to the BigFix Compliance product and you must be using BigFix version 10.0.0 and later.
If you use custom sites, update your custom sites accordingly to use the latest content. You can synchronize your content by using the Synchronize Custom Checks wizard. For more information, see Using the Synchronize Custom Checks wizard
More information:
To know more about the BigFix Compliance SCM checklists, please see the following resources:
BigFix Forum:
Compliance (Release Announcements)
This category is used by HCL to announce new releases for BigFix Compliance.
BigFix Compliance SCM Checklists:
SCM Checklists
This category is the central reference for all SCM Checklists supported by BigFix Compliance. It covers the complete list of active checklists across all supported frameworks and platforms, including CIS, DISA STIG, PCI DSS, NIST, and more, along with site name, version details, and supported OS versions.
We hope you find this latest release of SCM content useful and effective. Thank you!
– The BigFix Compliance team
