Product:
BigFix Compliance
Title:
Updated CIS Red Hat Enterprise Linux 9 with bug fixes.
Security Benchmark:
CIS Red Hat Enterprise Linux 9 Benchmark, v1.0.0
Published Sites:
CIS Checklist for RHEL 9, site version 7
(The site version is provided for air-gap customers.)
Details:
- Fixed and Improved implementation for the following check:
4.1.1.2 - Ensure auditing for processes that start prior to auditd is enabled
4.1.1.3 - Ensure audit_backlog_limit is sufficient
3.3.7 - Ensure Reverse Path Filtering is enabled
1.1.2.1 - Ensure /tmp is a separate partition
4.1.3.6 - Ensure use of privileged commands are collected
4.2.2.1.3 - Ensure systemd - journal - remote is enabled
4.2.2.5 - Ensure journald is not configured to send logs to rsyslog
5.2.7 - Ensure SSH root login is disabled
4.1.3.9 - Ensure discretionary access control permission modification events are collected
6.1.9 - Ensure no world writable files exist
6.1.10 - Ensure no unowned files or directories exist
6.1.11 - Ensure no ungrouped files or directories exist
6.1.12 - Ensure sticky bit is set on all world - writable directories
Actions to take:
- To subscribe to the above site, you can use the License Overview Dashboard to enable and gather the site. Note that you must be entitled to the BigFix Compliance product, and you must be using BigFix version 9.2 and later.
- If you use custom sites, update your custom sites accordingly to use the latest content. You can synchronize your content by using the Synchronize Custom Checks wizard. For more information, see Using the Synchronize Custom Checks wizard
More information:
To know more about the BigFix Compliance SCM checklists, please see the following resources:
- BigFix Forum:
https://forum.bigfix.com/c/release-announcements/compliance - BigFix Compliance SCM Checklists:
Welcome to Wikis
We hope you find this latest release of SCM content useful and effective. Thank you!
– The BigFix Compliance team
