BigFix Compliance PCI Add-on: Refresh PCI DSS Checklist for MS SQL 2019 (PCI v4.0), published 2025-09-18
Product:
Title:
Category:
PCI DSS Checklist
Security Benchmark:
Payment Card Industry Data Security Standard v4.0.1
Published Sites:
PCI DSS Checklist for MS SQL 2019 (PCI v4.0), site version 2.
PCI DSS Reporting, version 28.
(The site version is provided for air-gap customers.)
Details:
  • Total Fixlets in the site: 74
  • Total Requirements covered: 8
  • Total Milestones covered: 4
  • Enhanced Compliance Coverage: This update strengthens our existing content to help you stay aligned with the latest guidance provided by the Payment Card Industry Data Security Standard (PCI DSS) v4.0.1requirements.
  • Improved Security: Includes enhanced security controls for better protection.
  • Support for Always on Availability Groups (AAG): Ensures compatibility with SQL Server AAG configurations.
  • Failover Cluster Support: Fully applicable to SQL failover cluster environments.
  • Custom Checks Wizard Support : The Synchronize Custom Checks wizard is now supported.
  • The following PCI DSS Policies are refreshed with the latest content from PCI DSS Checklist for MS SQL 2019 (PCI v4.0) site:
PCI DSS Checklists
PCI DSS Milestones View
PCI DSS Requirements View
Actions to take:
Use the License Overview dashboard from the BES Support site to enable and gather the said site. Note that you must be entitled to the new content, and you are using BigFix version 10.0 and later.
If this is your first time using the PCI DSS Checklist for MS SQL 2019 (PCI v4.0), please create a custom site to display the MS SQL 2019 results in the PCI DSS Policy Reports.
For Existing Users: Please follow the steps below to update your setup:
Remove the Environment Setup Task and omit requirement Fixlets from your custom site.
Synchronize your checklist with the external site using the Synchronize Custom Checks Wizard.
Once synchronization is complete, create a custom copy of the Environment Setup Task from the external site and add it to your custom site.
If you were involved in the Beta / Early Access Program for BigFix Compliance PCI Add-on, unsubscribe from the beta sites to avoid any conflicting issues with the production sites. If you do not unsubscribe from beta sites, the content in the production sites will fail.
More information:
To know more about the BigFix Compliance PCI DSS checklists, please see the following resources:
BigFix Forum:
BigFix Compliance SCM Checklists: Welcome to Wikis
BigFix PCI Add-on User’s Guide:
We hope you find this latest release of SCM content useful and effective. Thank you!
– The BigFix Compliance PCI Add-on team
