I am looking for bigfix administrator guide for platform 11 for internal training purpose. The one https://support.bigfix.com/product/documents/BES_Admin_Guide_72_090723.pdf which I could find and few others are for old platform. Can someone share with me please
Are any of the PDF guides on Platform guides in PDF format of any help for you? Not sure there is an overall admin guides as was the case in older version as the product has grown so much since then.
I guess I will start working on it and will try to create a guide similar to previous versions
In case it helps, there's quite a lot of training material (including self-paced courses) freely available here: HCL BigFix Training Courses and Certifications from Technical Experts
If you’re looking for configuration, maintenance and non-fuctional requirements, you might check out the guides here: Technical Documents
BigFix_11.0.6_Admin_Relevance_Guide.pdf (57.9 KB)
I have created a file but will keep on working to make it more comprehensive so that any new operator can find the guide at one place which we used to have for version 9.
