BFOSD is Busy (OSD)
Getting BFOSd is currently is busy processing some post-installation task…
Ran baremetal sync task and restarted relay and client service but still still getting the same issue…
Hello,
it seems that the bare metal server is busy in initialization activities after restart. It could take some time if the bare metal server has a long run and deployment history to re-scan it.
If it takes a lot of hours or it’s stuck on that screen, I suggest to contact the product support.
Thanks.
