BFI Customers Heads-Up
Have been working on a case for over a year and part of this case we discovered that residual data is being left behind by the product at this location \Program Files (x86)\BigFix Enterprise\BES Server\UploadManagerData\BufferDir\sha1 which is causing us to unnecessarily chase issues for Oracle inventory purposes.
Strongly suggest you vote on this idea, HCL Software - Sign In
This idea is to cleanup after an import OR reset the \Program Files (x86)\BigFix Enterprise\BES Server\UploadManagerData\BufferDir\sha1\(nn)\(id) folder BEFORE any scanning takes place.
This way, there is no stale data left behind by inventory scans that may have run months or years ago.
Can you provide a bit more detail? Is there some software being discovered on the root server that is not expected?
Lots of residual stale data from previous scans. Imports do not do any cleanup after the data is processed by nightly imports and that has created data issues for Oracle Measurements data files.
In lieu of the idea above, we implemented the following to run hourly:
Get-ChildItem -Path “D:\Program Files (x86)\BigFix Enterprise\BES Server\UploadManagerData\BufferDir\sha1*” -File -Recurse | Where-Object { $_.LastWriteTime -lt (Get-Date).AddDays(-8) } | Remove-Item -Force
Our \sha1 is on D: and we scan all endpoints every 7d, hence the adddays(-8) above.
YMMV.
Right, just to be clear Inventory may not be the only thing storing scan archives. It’s common for customers to roll up logfiles or other data through custom uploads; and the Unmanaged Asset Importer uploads here as well.
Deletion of uploads for a given computer should happen when that computer is deleted, and the BESAdmin Cleanup tool runs to remove that computer’s upload files.
Old scan files left behind should not, I think, trigger a new detection in BFI; the “last seen” date for a software package should match the date of the old scan uploads I believe. If that’s not correct then I think you might levy a bug report on that.
If the computer has an Inventory scan, then removed the software but never ran a new Inventory scan, then I think the BFI Inventory should continue to report that software as long as the target computer exists in BigFix, Inventory won’t detect the uninstall until a new scan is uploaded & imported, but I think that is expected behavior.
In my case, they will have 7d to get their data off of \sha1 before it gets nuked.
With the case I have open for going on 14mos, old scan files ARE having an impact on Oracle collected data. I have no choice but to do the cleanup on my own that the product fails to do.
The residual files you are referring to are on the BFI server and left there after an import from the BigFix LifeCycle server.
They are also left here \Program Files (x86)\BigFix Enterprise\BES Server\UploadManagerData\BufferDir\sha1<nn><id> and that is where the problem is.
bigfix-ideas.hcltechsw.com/ideas/BFINV-I-280
