Any idea why “extract” can’t find the path. file is archive using “bfarchive”.
I have to create the archive which can extracted in unix and wintel. “tar” is present across unix but not in wintel. “unzip” is present in unix but not sure if its present across wintel or not. I don’t have control over wintel server. so bfarchive is best option i have.
ActionLogMessage: (action:1733938) Download url: 'http://xyz:52311/Uploads/95a06829ac1a5346071c5a92c5aad70398d45886/bf_arch’
ActionLogMessage: (action:1733938) Action signature verified for Execution
ActionLogMessage: (action:1733938) starting action
At 10:38:18 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded delete No ‘/tmp/bf_arch’ exists to delete, no failure reported (action:1733938)
Command started - wait mkdir /tmp/MQ (action:1733938)
At 10:38:19 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=1) wait mkdir /tmp/MQ (action:1733938)
At 10:38:20 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command started - wait extract bf_arch “/tmp/MQ” (action:1733938)
At 10:38:21 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command failed (child exec() failed (errno is 2: No such file or directory) wait extract bf_arch “/tmp/MQ” (action:1733938)
At 10:38:21 -0400 -
ActionLogMessage: (action:1733928) Download url: 'http://xyz:52311/Uploads/95a06829ac1a5346071c5a92c5aad70398d45886/bf_arch’
ActionLogMessage: (action:1733928) Action signature verified for Execution
ActionLogMessage: (action:1733928) starting action
At 10:06:00 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded delete /tmp/bf_arch (action:1733928)
Command started - wait mkdir /tmp/MQ (action:1733928)
At 10:06:01 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=1) wait mkdir /tmp/MQ (action:1733928)
At 10:06:03 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command started - wait extract bf_arch /tmp/MQ (action:1733928)
At 10:06:04 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command failed (child exec() failed (errno is 2: No such file or directory) wait extract bf_arch /tmp/MQ (action:1733928)
At 10:06:04 -0400 -
ActionLogMessage: (action:1733925) Download url: 'http://xyz:52311/Uploads/95a06829ac1a5346071c5a92c5aad70398d45886/bf_arch’
At 09:59:11 -0400 -
ActionLogMessage: (action:1733925) Action signature verified for Execution
ActionLogMessage: (action:1733925) starting action
At 09:59:13 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded delete No ‘/tmp/bf_arch’ exists to delete, no failure reported (action:1733925)
Command started - wait mkdir /tmp/MQ (action:1733925)
At 09:59:14 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=0) wait mkdir /tmp/MQ (action:1733925)
At 09:59:15 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded move __Download/bf_arch /tmp/bf_arch (action:1733925)
Command started - wait extract /tmp/bf_arch /tmp/MQ (action:1733925)
At 09:59:16 -0400 - actionsite (http://xyz:52311/cgi-bin/bfgather.exe/actionsite)
Command failed (child exec() failed (errno is 2: No such file or directory) wait extract /tmp/bf_arch /tmp/MQ (action:1733925)
At 09:59:16 -0400 -
ActionLogMessage: (action:1733925) ending action
