(imported topic written by Shlomi91)
just wanted to share something which may be helpful to you citrix admin guys:
if you publish A citrix application on a server which has Bigfix client, you may notice that when a user closes the published application, his session may remain active, and may prevent him from logging on again (depending on concurrent session limits you may have placed).
I found that the BesClientUI.exe process is preventing a smooth logoff, but a small registry tweak takes care of that.
All you need to do is to add the following registry entry to the server, and you are good to go:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Citrix\wfshell\TWI]
"LogoffCheckSysModules"=
"BESClientUI.exe"
Hope this helps someone…
link to Citrix’s relevant KB:
Graceful Logoff from a Published Application May Render the Session in Active State
Shlomi
