The BigFix Agent very slowly investigates various parts of the system to do continuous checks to make sure everything is up-to-date and configured properly. It tends to use 0-1% of the overall system resources and absolutely is not supposed to cause any system problems. The reason you see the agent have many I/O Read/Writes is because the agent is always on and so the numbers accumulate over time, but it doesn’t mean that the agent is affecting system performance.
Have you been able to isolate that the BigFix Agent is indeed the cause of the computer being slow and the typing being slow? The simple way to test this is to try to run the system for a while with the agent disabled. If the agent running appears to be correlated with the slowness, then it is certainly an issue and I recommend that you start up a support case so we can look at it in more detail.
Here is what to expect from the BigFix agent in terms of resource usage:
Bummer, I seem to be having the same problem with a new Vista machine running 7.0.1 Client. Opening email and typing is delayed by 2-3 seconds and it goes back to normal once I stop the BESClient.
CPU usage is less that 2%, but Disk I/O is huge. Using Task Manager, I added columns for I/O Read, I/O Writes and I/O Other. BESClient is the largest consumer of resources in the list, with I/O Other the largest of the three. The numbers are incrementing by several hundred on every refresh more that anything else running.
Is there some way to see what it’s doing and maybe find a fix for it.
We probably want to do some more advanced troubleshooting with you through tech support. Specifically, we would like to gather the BES Client Diagnostics and review the EMsg logging at a level of 10,000. The EMsg log will tell us exactly what the client is doing and how long its taking to do it.
I don’t think that the Disk I/O characteristics that you described are the root of the problem. The BES Client has the same characteristics you mentioned on every computer but this doesn’t lead to any problems. Further, the agent is not event driven so it seems weird that you have issues when doing specific activities (ie, the client doesn’t change what its doing when you open a document and type into it). We certainly want to get to the root of the problem and fix it for you but the disk I/O is probably a red herring.
Pardon my ignorance, but where would I find this console thing? I’m betting we got a partial install from IT that didn’t include this. Assuming I can get the registry hacks in place, where do the logs go, and how would I get them to you? BESClient is version 6.0.21.5. The only other executable I have is WinBESAgentUI.exe, which won’t start interactively.
As another follow-up, one of the other big consumers of I/O is McAfee virus scan. I’m pretty sure its set to scan all file reads and writes. In the performance tuning tips on the BigFix site, it makes mention that there are lots of small files that are read or written when BESClient runs. I can’t kill McAfee, so I can’t tell if the combination is causing the impact. The other thing I found was in the BESClient logs: C:\Program Files\BigFix Enterprise\BES Client__BESData\BES Support\1Performance.fxf warnings about Windows file indexing being enabled, BES Server/Relays are Set to use Compression, The listed BES Servers/Relays have the BES folder compressed, BES Server Does Not Meet Recommended Requirements, etc. This file is dated 4/4/2006, so it may or may not reflect current status. Are there any other logs I can get some clues from?
The BES Server/Relays can suffer performance issues from some of the AV scanners if the components are under high load. This does not tend to be a problem for the agents.
How many agents are having this problem? does this issue occur often or is it sporadic?
It is possible you can have an issue like this that is related to some custom properties that are too aggressive, but as Tyler mentioned, we can do some investigations to try to find this…
Also, if you temporarily disable the McAfee service, does this issue seem to go away?
Disk I/O - the numbers are indeed high, but do not affect system performance.
McAfee Antivirus - i excluded the C:\Program Files\BigFix Enterprise\BES Client__BESData folder from scans in ePO, and that solved this problem.
McAfee HIPS, however, is a whole new story:
i am currently testing HIPS deployment in my organization, and i found that when both BESClient and McAfee HIPS are working, the computer has terrible response time.
disabling any of these (wither HIPS or BESClient service) will release the computer’s resources.
looking in McAfee KB i found nothing.
Chris / Ernie, do you also have McAfee HIPS installed?
One of our other customers reported that McAfee HIPS was causing an issue similar to the one that you described. The status update I heard from the customer was that McAfee was looking into it now and we have made ourselves available to McAfee to help answer any questions that they might have.
We heard back from McAfee and they said that their 6.1 agent did not work well with applications that did a lot of registry access. McAfee 7.0 HIPS agent apparently resolves this issue.
I am with the customer Ben is referring to. This problem was supposed to have been fixed with HIPS version 7, however, this is not the case. If you have HIPS 6.1 or 7.0 and BESClient 7.0, then this will cause you a problem. There is no problem with HIPS and BESClient 6 I have tested a work around for the problem and it seems to be working. Here’s what we did:
First, in the Policy Catalog, we added BigFix to our Trusted Applications list. We then went into the IPS Rules and put in an exclusion in our Application Protection Rules for Bigfix. Finally, we created an exception rule in our IPS Rules for the BESClient for rule 1002.
Essentially, the problem is that McAfee does not allow BigFix to enumerate the registry for a number of HIPS related keys. Rule 1002 is the signature that protects the registry from viewing. Granting BigFix an exception to this signature seems to do well as a workaround.
