I just tried it and I can reproduce the issue on Vista (it seems to happen with some other dashboards too)… We will take a closer look… thanks for the report.
OK… found the issue… it is a Microsoft bug that is related to the “Office Web Components 10” that we use for some of our charts in dashboards. There appears to be a problem running Office Web Components 10 with the Vista DEP mechanism.
We have found that you can upgrade to Office Web Components 11 (2003 version) to fix this issue. More info on how to upgrade here:
Rock on. I never installed OWC11, 'cause I never really had any reason to use it. Now I do.
I think the most valuable part of posting issues on the public forum is that the issue (and resolution) becomes searchable even if no official knowledgebase article is created. I’d like to recommend y’all figure out some way to make the forum more visible to the average BES admin. Perhaps including the User Forum as a default search, i.e. the box is checked by default, but the search results from the forum are the last results returned, to make sure “official content” results are returned first. I dunno, that’s just one BES guy’s suggestion.
