I would think once the BESClient passes the command to the system for a patch, the system would use whatever process it uses to install that patch meaning it’s then out of the BESClient’s hands and the usage of the BESClient would be irrelevant. Maybe I’m missing something?
The reasoning is actually that the BES Client CPU usage set to <10% only applies to background relevance evaluation and does not apply during action execution at all. If you are using relevance substitution during actionscript, it is not bound by the <10% CPU usage.
Setting a higher CPU usage for the BES Client may make it more reactive to finding things that are made relevant by previous actions, so it could actually speed things up a bit, but not during action execution.
On windows systems, you can actually set the process priority that the BES Client will execute actions with:
It is a good idea for long running background tasks to be launched at low priority on windows systems, particularly when a user is logged on at the time, or may log in while it is running.
