BES Client Setting : Client UI Balloon Mode Selection
(imported topic written by sainathss91)
Hi all,
Below is my setup
Subnet : single subnet
Servers : BES server installed on Windows 2k8 ( 192.168.1.2)
BES Console + BES relay installed on other windows 2k8 ( 192.168.1.3 ) (bigfixrelay.sai.com)
Database configured on SQL server ( 192.168.1.4)
Having One win2k8 for testing
Domain : all the above 4 systems are in one domain (sai.com)
BES Clients : installed BES clients on all server except Database
Issue : when i set BES client UI ballon , it doesnt appear anywhere,
Configuration followed : i went to fixlets -->BES Client Setting : Client UI Balloon Mode Selection --> balloon mode to halfballoon --> selected 192.168.1.3 ( relay server ) --> under exectution removed “ends on” --> ok
the above doesnt do anything , i checked on 2 systems , but cannot see ballon
question : a) where does this half balloon appears ?
b) suggest me if the procedure above is correct ?
When you say you selected the Relay, did you target just the relay, or all the computers that are connected to that relay? If you select just the relay it does not mean that all the machines connected to that relay will get the same action.
