Hi there,
Recently i’m facing an issue with my OSD server, its not syncing and tried even removing it and reinstall but same issue happens.
below are where the issue happens, need support if any one encountered same issue before.
The Delta sync fails
Failed Update WinPE 10 Resources on Bare Metal Servers
Failed continue if {(value “SyncTimePE” of key “HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\EnterpriseClient\OSDControl” of registry as integer)|0 >= 1582200725294}
And the full sync also fails
Failed Restart Bare Metal Server Services (Full Sync)
Failed continue if {exists file (parameter “READYTESTPATH” of action) whose (not exists lines whose (it as string contains “Resource temporarily unavailable”) of it)}
