Assets discovery fails with network range
(imported topic written by rad.ricka91)
Hello boys and girls,
just wondering if anybody else is getting failures with asset discover (nmap) when scanning a specific subnet range.
Scan of local subnet works perfectly well. Scan of a range such as (192.168.1.1-254) fails at
continue if {(exists file whose (name of it starts with “nmap-” AND exists line whose (it as lowercase contains “nmap run completed at”) of it) of folder (pathname of windows folder & “\temp\nmap”))}
… even though the file seems to exist.
Just wondering if anybody’s seen it before. I haven’t had the time to troubleshoot it properly yet, so don’t spend time on it ;)))
Thanks,
Rad
(imported comment written by rad.ricka91)
Hello,
so further search revealed that the nmap engine fails with " failed to determine route to xxx.xxx.xxx.xxx" despite default route being present. This seems to be a well known issue if you google it, but no solutions in sight. The client is subnetted on /28 network, while the network being scanned is /24.
If a local adress/interface is specified (-S) then nmap quits with “NmapArpCache() can only take IPv4 addresses”.
Problem seems to be just with nmap, rather then BF.
R.
