Asset Discovery and Scan
How to discover Clients having different Subnet mask than that of TEM Server using NMAP Asset Discovery?
Can anybody help ?
(imported comment written by CPass)
NOTE: If you do not have an “Unmanaged Assets” folder currently appearing in your Content list then there is an action that needs to be taken on the Bigfix server. Unfortuntaly since I do not manage these servers at our company I am not sure what this action is. I’m sure it is documented in the admin guide or someone from the community can chime in.
Once the above has benn done run the task “Designate NMAP Scan Point” on one PC in every segment of your network.
When that’s completed run the task “Run NMAP Scan” and select all your NMAP PC’s.
This will evenutually populate the Unmanaged Assets folder.
Regards
