This is also only if your “default_email.bat” file is already there and the “RunAsCurrentUser.exe” is downloaded with the fixlet as well.
Conversely, you could try to package your Whoami executable with it and run your command directly against it since, given this ActionScript, you would need to do it with the “RunAsCurrentUser.exe” anyway if it’s not already on the machine. Here is a link to the page on RunAsCurrentUser.exe use which I’m sure you’ve already looked at.
You would need the SHA1, the full path to where it would sit on your BES Server, and the prefetch statement. All of which is actually pretty easy with the SHA1 Tool.
