Hello,
I am trying to put together a tasks to create local accounts, change local passwords. I already have the scripts to do so that take a text file input and they work very well, so I plugged them in tasks and generate the text file throught the script on the go - they still work. However, it leaves the password as a string within the actionscript and anybody can read them, so I wrote an external VBscript that I will distribute that converts a regular string into an ascii code (Ex. “%54%65%73%74%31%32%33”) and now when I plug in the ascii code in the task it does not convert it back to a string.
This version works (ascii code hardcoded within the actionscript):
delete __appendfile delete admins.dat appendfile
"user1"
} appendfile
"%54%65%73%74%31%32%33"
} move __appendfile Admins.dat
This version works with regular strings but it does
NOT
convert the ascii code back to a string:
action parameter query
"username" with description
"Please provide username" with
default value
"user1" action parameter query
"password" with description
"Please provide password" with
default value
"" delete __appendfile delete admins.dat appendfile
{parameter
"username"
} appendfile
{parameter
"password"
I even tried to pass several combinations (see below) but none seem to make a difference:
{"%54%65%73%74%31%32%33"}
Is there something I am missing? Is there an easier way to come up with a solution that will provide some kind of security instead of ascii conversion. Please advise.
ageorgiev
