Files that are uploaded in the Archive Manager have their names sanitized for compatibility between different operating systems and codepages. The original name would be within the index.txt file when it was uploaded
thanks for this information.
Yes, the original name is in the index.txt file like:
/var/tmp/tsmlog/server1@server1%23dsmsched.log
means: @ will be in place // # is replaces by %23
Why are you uploading this to the root server at all? Is this for debugging and troubleshooting only?
You can get the status of TSM backups using a BigFix analysis without the need to upload these files.
In most cases I wouldn’t recommend using upload manager at all when you can write an analysis to pull out just the info you need and it can automatically get the data every 12 hours or whatever interval you choose.
