Hi , is there any method for application release management / method via Bigfix?
Some additional details about what you are looking for would be helpful.
Hi Tim, I am looking out to install few in-house applications with version control and it should be auto install on the desired host or maybe the list will be available to the end server for the required software.
Idea is to install the application with version control and deploy/uninstall / re-deploy the software list to the end server with bigfix client on TESt / DEV server then deploy on prod servers.
