how can i see applicable components in baseline for specipic computer?
with relevance query
Check your Web Reports report list and see if you have a report called “Computer to Baseline Audit Report” (I’m pretty sure it’s a canned report.) If so, you can select an individual computer and a particular baseline, and it will show you the relevant components of that baseline for the endpoint. Hope that helps!
