My server corrupted so i reinstall my whole TEM Application. When configure the MDM i facing this issue “APNS key does not match APNS certificate”.
Thank You.
Thank You.
This will happen if you your Apple APNS certificate does not match the private key you generated.
Here is how it works:
To fix this, you can either:
