Hello Just want to ask around about https://chocolatey.org/
I just wanted to know if anyone is using chocolatey and bigfix together
It should be pretty easy to install chocolatey; there is a fixlet already;
https://bigfix.me/fixlet/details/6080
It didn’t install correctly in my Windows 10 VM so I coudln’t use this fixlet
so I’m working on an installer myself.
I just think it would be great for people doing image deployments and want Free apps to install or upgrade.
Was thinking of doing something like this; call for a upgrade
Then do a upgrade; and if the app isn’t there install it. Just like one super action but the more actions the more room for issues; here is what I was thinking of doing.
choco upgrade chocolatey
choco upgrade -y vlc googlechrome Firefox notepadplusplu flashplayerplugin jre8 flashplayeractivex 7zip.install ccleaner adobeshockwaveplayer
cinst -y vlc googlechrome Firefox notepadplusplu flashplayerplugin jre8 flashplayeractivex 7zip.install ccleaner adobeshockwaveplayer
This could automate apps I want on my machines like
VCL Media Player, Browser,s Flash and JRE and Zip
So Far I’m close but have not gotten it to work yet;
I need to work on an installer that runs with Bigfix and then a action so I can run it
here is what I have but this doesn’t work
Script Type BigFix Action Script
waithidden “C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe” -ExecutionPolicy Bypass -command “choco install vlc 7zip.install ccleaner adobeshockwaveplayer -y --no-progress”
This doesn’t work; says runs and complete; I’ll have to run a log file and see whats going on
I then tried to run as adminisator with cmd with thhis
waithidden cmd /c “choco upgrade notepadplusplu flashplayerplugin jre8 flashplayeractivex -y --no-progress”
Call to run it in power shell; this will fail.
I have only been playing with this for a bit; if anyone has this up and running and you could share with me a solution that would be great. Otherwise I will grind this out in my spare time and work on a solution to share
