So, I understand how to use the following:
substrings separated by " " of "a b c d e"
What I’d like to do is get the exact same results from the following:
substrings separated by "" of "abcde"
Is there a way to do this in BigFix Relevance?
Yes, using the characters inspector:
(it & ". Item") of characters of "ABCDE"
A tip:
Use the properties inspector in the Fixlet Debugger to get all of the properties / inspectors you can use.
You can even filter the list of properties to just contain those that work on strings and substrings:
(it as string) whose(it contains "string>: " AND it ends with "string") of properties
And you can alphabetize the results like this:
unique values of (it as string) whose(it contains "string>: " AND it ends with "string") of properties
