I have 4 sites where we are ensuring that all Computer Properties, Analyses, and Web Reports are matched (Obviously custom fixlets are not a prob). We are all currently running 5.1 (6.0+ coming soon I hope). I know in 6.0 you can export / import properties which would be a big help but what about Web Reports?
The Web Reports are great, but before we get too many of them, I want to know if I need to just deal with having to create them manually at each site or is there a light at the end of the tunnel to make this easier to setup and stay matched.
All the public/private report definitions are stored in the BESREPORTING database in the SAVED_REPORTS table. If you want to move them between servers, you can insert the rows directly in the database with some basic SQL.
I have a few web reports where the query data is pretty much static but the computer list needs updating. The computer list consists of 100 or so machines. I have to manually input each machine name in the filter.
Is there a way to export the filter, edit it and re-import the filter?
Or inject a new filter of the list of computers into SQL so that I can import the filter from the Web reports console?
