Another test parsing question
I’m having problems with this. It doesn’t seem to be working. Is it because of the double quotes around the “CheckVers=“YES”” & “CheckVers=“NO”” ?thanks
// store the file location
parameter “filename” = “{name of drive of system folder & “\pbapps\frates\fr.ini”}”
parameter “textToReplace” = “CheckVers=“YES””
parameter “newText” = “CheckVers=“NO””
// iterate through the file replacing lines as necessary
appendfile {concatenation “%0d%0a” of ( if (it contains (parameter “textToReplace”)) then ((preceding text of first (parameter “textToReplace”) of it) & (parameter “newText”) & (following text of first (parameter “textToReplace”) of it) ) else it ) of lines of file (parameter “filename”)}
hmm… maybe try something like this:
parameter “textToReplace” = “{“CheckVers=%22YES%22”}”
I did not test this, but %22 is used for escaped quotes, AFAIK.
No luck with:
parameter “newText” = “{“CheckVers=%22NO%22”}”
This:
Will end up:
“CheckVers=“Yes””
I think you want either:
parameter “textToReplace” = {“CheckVers=%22YES%22”} // will be: CheckVers=“Yes”
Or:
parameter “textToReplace” = “CheckVers=%22YES%22” // will be: “CheckVers=“Yes””
So here’s the strange thing. I set it back to just “CheckVers=“YES”” & “CheckVers=“NO”” and in the bigfix log file, it shows the contents of the file that I am parsing (along with the correct NewText), however, the file that I am trying to modify never changes.
anyone?
I had success with:
parameter “replace”=“CheckVers=“YES””
parameter “new”=“CheckVers=“NO””
And, yes, the fact that we allow those non-escaped double-quotes is weird. (Just my personal opinion.)
Also, make sure you check for case-sensitivity issues.
Same thing. It shows it correct in the bigfix log file, but never updates the actual file. Can you provide your appendfile command?
Is your Action Script in the first post your complete script? It is missing
copy “{parameter “filename”}” “{parameter “filename” & “.bak”}”
delete “{parameter “filename”}”
copy __appendfile “{parameter “filename”}”
Yup, that was it. thanks Noah. I was missing those 3 lines. I was wondering how the action modified the file.
thanks again.
(imported comment written by khanand91)
hi,
i’m trying to figure the best way to remove the unwanted CRLF at the end of a text file. I can see the CRLF there when I open the file in a text editor but when I search file the line in action script it doesnt seem to register … here’s the test I tried in the fixlet debugger.
if {exists lines whose (it contains “%0d%0a”) of file “C:\Program Files (x86)\BigFix Enterprise\BES Client\textfile.txt”}
appendfile TRUE
else
appendfile FALSE
endif
this gives me a blank in Q&A which must be the CRLF so the debugger can see it …
line (number of lines of it) of file "C:\Program Files (x86)\BigFix Enterprise\BES Client\Inv_scan_files\textfile.txt
and (number of lines of it) of file "C:\Program Files (x86)\BigFix Enterprise\BES Client\Inv_scan_files\textfile.txt gives me the line number of the line at the end that just has a CRLF
thanks all
Your last expression:
… will only tell you the number of lines in the file.
Do you want a file with no CRLF’s in it at all or do you want to remove CRLF only from the last line?
hi jesse, yes i was using the last example ( number of lines ) to demonstrate that the last line wwas indeed the CRLF and not any actual text. I just want to remove the CRLF from the last line ideally.
thanks
ok. so you want to do something like this:
createfile until __ENDCREATE
{concatenation “%0D%0A” of (if (line number of item 1 of it = item 0 of it AND item 1 of it ends with “%0D%0A”) then (preceding text of last “%0D%0A” of item 1 of it) else (item 1 of it)) of (number of lines of it, lines of it) of file “c:\foo.txt”}
__ENDCREATE
delete c:\foo.txt
move __createfile c:\foo.txt
