Hello,
I have created custom client settings called Environment, which value is DEV/QAU/PRD depends on the system.
I would like see these values in Computers view, so I can easily sort and filter our clients according to it.
I believe that its possible via analyses and then select such result via column picker within Computers view.
I know how to query the registry with this parameter, but I believe there is some other (easier) option, how to receive value of this settings directly via BigFix syntax.
Can you advise me here?
Thank you
