Hello,
I would like to write a analyse for all connected Disks on Windows Clients. The output should include the following information/format:
Drive, total capacity, free, free in %, serialnumber.
I am tested the following statements:
- Statement
(string value of property “DriveLetter” of it, (string value of property “Capacity” of it as integer / 1024 / 1024 / 1024) as string & " GB", (string value of property “FreeSpace” of it as integer / 1024 / 1024 / 1024) as string & " GB",
((string value of property “FreeSpace” of it as floating point / string value of property “Capacity” of it as floating point * 100) as integer as string & " percent free" of it), (string value of property “SerialNumber” of it)) of
(select objects (“Label,DriveLetter, Capacity,FreeSpace, SerialNumber from Win32_Volume where DriveLetter= ‘C:’”) of WMI)
- Statement
if (exists wmi) then (concatenation ", " of (((substrings after “=” whose(it as trimmed string != “”) of (property “SerialNumber” of it as string)) of select objects “* from win32_PhysicalMedia where SerialNumber != ‘’” of wmi) as
trimmed string)) else “n/a”
now my questions:
- Why is the serialnumber within the object Win32_Volume differnt to the object win32_PhysicalMedia?
- If I want to have the serialnumber from the win32_PhysicalMedia, how can I combine this with the first statement?
- If I remove the where clause "where DriveLetter= ‘C:’ from the first statement, I got an error “Singular expression refers to nonexistent object”
Thanks for helping
Josef
