In almost all cases, you should use Copy or Copy + Delete in BigFix ActionScript and not Move.
You might think that Copy + Delete is equivalent to Move in ActionScript, but at least in Windows, it is not.
I believe the difference is that a file copied will inherit permissions from the destination folder, while a file moved will not. I assume this means it inherits permissions from the origin folder, but I really don’t know for sure.
I have run into issues where I use the move actionscript command to put a file on the system that all users should be able to read, including non-admins, but because I used the move command, they could not. Generally in my experience this is not the desired behavior unless the file being moved is a log file or something similar that you don’t want most users to be able to read.
Related:
This Post:
Always Use Copy, Never Use Move
- BigFix Forum Post - make comments here
- GitHub Source File - suggest improvements here
- Website - Generated Blog Page
