Hi all,
I have installed Tivoli endpoint Manager 8.1, and AIX Patch Management,
I’m trying the aixdowloadcacher, with the task from the console, and also manually, but it does not work, from the server and from my laptop.
From the TEM server, if I will specify a proxy without authorization, I obtained an error because the tool tried the
http://@:proxy.int:8080 syntax, and could not work.
From my laptop,
C:\2011>AIXDownloadCacher.exe c:\temp ACTIVE 6100-06-02-1044
Thu Mar 10 11:33:13 2011
Use FTP MODE: ACTIVE
Specified Packes: 6100-06-02-1044
Thu Mar 10 11:33:28 2011
==> Start working on 6100-06-02-1044
Thu Mar 10 11:34:07 2011
Skipping download of 6100-06-02-1044 while connecting to ftp server: Invalid argument
In PASSIVE mode I obtained the same
6100-06-02-1044 exists on www.ibm…com/support/fixcentral
Something changed in FTP IBM sites and AIXdownloadCacher is not updated ?
Thanks …
Graziano
