Advice and documentation on using authenticating relays
Do we know if this issue has been corrected in 9.2.2.21? I was looking into turning the authenticated relay encryption on my DMZ relay, but not sure what else I needed to do, restart relay service, etc. Or, if I had to do anything to the clients? If anyone has any experience with this, I would appreciate it, thank you for your time.
Are you seeing this particular issue or are you looking for documentation on how to use authenticating relays ?
Just looking for info how to do it properly. I am iffy about turning it on because I don’t know enough about how it is supposed to work with the clients passing through it and how those clients respond when not going through that relay anymore without encryption turned on. I am interested in only turning this onto our DMZ relay.
I also saw the post above about potential loss of relay affiliation and clients not checking in, etc. I wanted to know more about how to execute this properly. Thank you
