Actions failing with same exit code
Hello team,
Does anyone have a way of getting a list of machines that reported a given exit code for a certain fixlet that are deployed in separate actions?
Let’s say the MS Edge update was deployed on two separate actions and some machines that were targeted with Action1 and Action2 returned exit cod 3017. So the list for the machines that returned exit code 3017 is what we would like to get.
First you’d need to know how to send Session Relevance queries. I have a couple of brief examples at Passing relay property to client in software deployment task - #14 by JasonWalker
Once you can send Session Relevance queries, here’s an example that may be useful. You could also change the ‘exit code’ and ‘name’ filters to run any other query you like. In the example output, I was actually querying for name “MS23-FEB” and exit code 3010…
q: (ids of actions of it, name of computer of it|"Computername Not Reported", (id of it, name of site of it, name of it) of source fixlets of actions of it, start times of it, exit codes of it) of results whose (exit code of it = 3017) of bes actions whose (name of source fixlet of it contains "Edge")
A: 3248, DC, ( 502278209, Enterprise Security, MS23-FEB: Cumulative Update for .NET Framework 3.5/4.7.2 for Windows Server 2019 - Windows Server 2019 - .NET Framework 3.5/4.7.2 - KB5022511 (x64) (Superseded) ), ( Wed, 08 Mar 2023 18:50:40 -0500 ), 3010
A: 3250, DC, ( 502284003, Enterprise Security, MS23-FEB: Cumulative Update for Windows Server 2019 - Windows Server 2019 - KB5022840 (x64) (Superseded) ), ( Wed, 08 Mar 2023 19:02:44 -0500 ), 3010
A: 3251, BFC, ( 502284201, Enterprise Security, MS23-FEB: Cumulative Update for Microsoft server operating system version 21H2 - Windows Server 2022 - KB5022842 (x64) (Superseded) ), ( Wed, 08 Mar 2023 18:07:45 -0500 ), 3010
A: 3251, BFI, ( 502284201, Enterprise Security, MS23-FEB: Cumulative Update for Microsoft server operating system version 21H2 - Windows Server 2022 - KB5022842 (x64) (Superseded) ), ( Wed, 08 Mar 2023 18:04:09 -0500 ), 3010
A: 3685, WIN2022-TEST1, ( 502273501, Enterprise Security, MS23-FEB: Cumulative Update for .NET Framework 3.5 and 4.8 for Windows Server 2022 - Windows Server 2022 - .NET Framework 3.5/4.8 - KB5022507 (x64) (Superseded) ), ( Tue, 04 Apr 2023 09:17:54 -0500 ), 3010
Hello Jason,
This is a great example! I forgot to mention that I was looking for the member action results and not the parent action result which the relevance above was able to get.
We are going to use to look for other machines that failed with the same instance of exit code.
Thank you very much! :slight_smile:
If I remember correctly, 3017 means a reboot is required.
