My requirement is to remove old software reboot the machine with providing a snooz time of 6 hrs and then re-install upgrade after a reboot
Created a baseline with 2 actions:-
Action -1 removes a software.
Action - 2 install’s upgraded version following a reboot.
In action 1 - I tried to enforce action setting lock in which I am locking Post action and asking a reboot with a popup message and differ time of 6 hrs.
Now, I tried to run this baseline with a Preset which gives a pre execution popup message to take action.
I received the Pop-up message to take action but there was no popup to reboot which was locked in the 1st action and the baseline just kept on running.
Is there a conflict between keeping a action setting lock and also using a preset in baseline action.
if you need client pop ups you can use dynamic deployment and create a relevance last boot time using “uptime of operating system” is over 6 hours, then servers are relevant for this deployment.
First deploy the unistall and reboot with normal deployment and then deploy the install with dynamic deployment with the uptime relevance.
If I use a reset and define something like a message to be sent while running the baseline and if the same is hardcoded in a action setting lock, then one of them is overlooked.
How to get a understanding about the same. I mean to say how to find out that which setting will override the other one.
Baseline preset setting will over ride the action setting lock. Or vice versa.
