@mfuglem, if your environment is having issues updating external content sites to the latest versions, you can leverage the Airgap utility to resolve. For example, if you were to see “failed to pass sha1 hash value checks” errors in your BESRelay.log it indicates that something between your root server and the BigFix sync servers has in someway modified the site download. This could be content filtering and or proxy config in your environment. Running the Airgap process will allow you to mitigate these issues. Utilization of the Airgap utility does not mandate the BES environment not be connected to the Internet.
Have you checked the BESRelay.log and GatherDB.log on your root BES server to see if you’re getting errors when trying to import version 1234 of the “BES Support” external site?
In my Linux lab, the only computer that is relevant for the Server Components fixlet is my BigFix server, not the BigFix console on another Windows computer, so I can’t target my console with this fixlet. This is why I asked the question originally. I’m led to believe, as @gearoid has stated, that I have to upgrade my console manually.
If you target using the dynamically target by property option what happens is that once the server has upgraded the fixlet becomes relevant on the console and then it will be upgrade by the fixlet.
Checked the log files and there are no error on importing the new site versions of 1233 and 1234. Log says it imported both successfully. A bit weird that my upgrade fixlet came in site version 1234, but i will take a closer look.
Instance 1
Windows Server 2012 Standard - SQL Server 2012
Time to upgrade (from the time I hit the last OK till the last windows indicating success.
Version 9.0.876 to version 9.2.6.94
8 minutes 20 seconds
My BFEnterprise DB Size:
Pre Upgrade: 1.7 GB
Post Upgrade: 3.6 GB (an extra 2 GB???)
Instance 2:
Windows Server 2012R2 - SQL Server 2014
Time: 8 min 30 sec
Pre Upgrade: 3.2 GB
Post Upgrade: 6.2 GB (3 GB Larger)
Instance 3:
Windows Server 2012 R2 - SQL Server 2014
Version 9.2.5.130 to version 9.2.6.94
Time: 26 min 30 secs
Pre Upgrade: 42 GB
Post Upgrade:42 GB (unchanged)
Going from version 9.0.876 to 9.2.6.94 the upgrade fixlet for the console never becomes relevant. Upon futher inspection of fixlet ID 2255 the relevance shows
(exists regapp “BESConsole.exe” whose (version of it < “9.2.6.94” AND version of it >= “9.1”)
Since my consoles are 9.0 the fixlet will never show relevant to upgrade the console. Easy enough fix to change the integer but before I do, can anyone at BigFix tell my why I should not upgrade from 9.0 to 9.2 of the console?
I can install the console upgrade manually on a system and it did it usual uninstall the old version and install the new version.
I think that may be a mistake in the relevance for the console upgrade, unless there is something odd that needs migrated in the console settings or ???
If the relevance is really there for a purpose, then it seems to suggest you need to install the 9.1 console and then install the latest console.
The content is reflecting that the server needed to be at 9.1 or greater to begin with so the upgrade to that version was expected. I can see how this is problematic in some cases so I’ll work on getting that changed going forward. Feel free to make a custom copy to fix it (for only the console alone portion)
When we can release the BigFix Remove Utility, Fixlet Debugger (QnA), RESTAPI Command-
line Interface (CLI), Computer Remover, Audit Trail Cleaner, Client Refresher, and Property ID Mapper for the IBM Bigfix 9.2.6.94?
