9.2 Deployment of Management Extender for VMware VCenter Missing
After upgrading to version 9.2 we are no longer able to deploy fixlet ID 801 “Deploy Management Extender for VMware vCenter”. It looks like only relays running older versions (.i.e. 8.2) show up as applicable. Anyone else run into this issue?
Judging by the relevance of the Task, I’m not seeing anything that would prevent it from applying to newer versions of Relays. Are the desired Relays subscribed to the site?
I believe I may have answered my own question, it looks like for versions 9.1 and higher you need to install the proxy agent, this can be done from the BigFix Management domain with fixlet ID 1836 “Install IBM Endpoint Manager Proxy Agent (version 9.2.0)”. Once this is installed the Deploy Management Extender VMware vCenter fixlet will show the newly deployed proxy agents as relevant.
