Wwwrootbes problems?
(imported topic written by bluerobin91)
Anyone know how to reinstall the bes web reports files? Attached is a screen capture of the wwwrootbes folder and for some reason it appears most of the core files for the web reports server is missing? Not sure if this was due to the recent upgrade…
You can try to “repair” using the installer and it should replace any files…
