Wwpn and a running process
(imported topic written by tazmir91)
Hi, I am looking to pull wwpn number from hba and for another property, need to check if a process mstragent.exe is running or not. Thx for the help
Use either a native utility or something like SANsurfer http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Product_detail.aspx?oemid=264 to dump HBA, WWPN, link/path status, etc. to a log file. Then use an analysis to parse the log to extract whatever info you are looking to find.
