Wireless Connection Issues after Windows 11 22H2 upgrade
Hi all, I recently rolled out a Windows 11 22H2 upgrade to some test computers at our company. I am finding after the clients upgrade from Windows 11 21H2 to Windows 11 22H2 the clients will not connect to company SSID which used 802.11x authentication using Radius. I did some research online. It looks like Microsoft has implemented TLS 1.3 in Win 11 22H2 which might be the cause of this. The only fix I have found for this is to forget the SSID on the computer and connect back to the wireless network. Seems to work after that. It looks like long term we may need to make some either make some changes on our radius server or script deleting the wireless profile and add it back.
I am curious if anyone else has ran into this and what you have done to fix this problem. We need to roll the upgrade out to over 2,000 clients here in the next few months.
